Isn't the kill switch usually of the momentary type?I guess I could wire the harness provided, to ground both the spark coils (7 amps), and see if the engine stops before the 5 amp insulation melts.
I just don't know how long the coils can be at maximum current without harming them.
The starter motor does not keep the gasoline engine running when there is no spark, so I think I can allow that to continue functioning. If the customer is arriving at his garage, hits the kill switch, and presses the starter button at the same time, I will have to find a way to disable the starter when activating the kill switch.
