Hardware requirement for the TCP IP Protocol
anukalp
Joined Jul 28, 2018
158
For educational purposes Please take the following hypothetical situation
System A ( Micro A is connected with Wi-Fi module A)
System B ( Micro B is connected with Wi-Fi module B)
System A can send data to System B. which protocol can be used, TCP/IP or WiFi between System A and System B?
I just want to understand when WiFi protocol will be used and when TCP/Ip protocol will be used
Papabravo
Joined Feb 24, 2006
22,111
TCP/IP can be used with any physical layer. You can use TCP/IP with a UART/RS-232 connection if you desire.
I'm not certain what you mean by WiFi protocol, but you can probably pass TCP/IP packets over that physical layer as well.
anukalp
Joined Jul 28, 2018
158
System A sending or receiving data to system B over protocol.
some protocols like TCP/IP, WiFi.
Is it the Wi-Fi module or the protocol or both?
Can two Wi-Fi devices send or receive data over the TCP/IP protocol?
Ya’akov
Joined Jan 27, 2019
10,291
WiFi operates at the physical and datalink layers, TCP/IP operates above that. WiFi and TCP/IP are not alternatives for each other.
