Hammond transformer dual primary and regular secondary question
kbyrne
Joined Dec 10, 2011
93
With my electricity at 115 VAC do I use a hammond with dots connected then other wires connected. One plug to dot and one plug wire to no dot. That would make up a parallel primary connection with 115vac input. Or would I hook up only one
set of primary wires. My schematic is different on my box than this pdf. Parallel causes a buzzing noise and I shut off power strip right away with transformer mounted on wood and wires insulated with white color euro type connector. I need this type of transformer clarified if anyone could help me. Part number 186F48 48VCT @ 2A.
RichardO
Joined May 4, 2013
2,270
It appears that you do not have the right phase of the connections for the primary or secondary. Double check your pin numbers.
Without a schematic of how you wired the transformer any further answers are impossible.
AlbertHall
Joined Jun 4, 2014
12,653
Your transformer should look like fig. 6D here. If it doesn't then ignore the information below.
You should connect pins 1 & 4 to one side of the mains and pins 2 & 5 to the other mains wire.
MaxHeadRoom
Joined Jul 18, 2013
30,807
If operating on 120vac then all you need to do is connect one ends of each pair together, and supply power to this junction and ONE of the other ends, then measure from each of the open end to the other, and the voltage will either be 120v or close to zero.
If 120v, swap one of the primary pair and connect in parallel.
Max.
kbyrne
Joined Dec 10, 2011
93
My transformer is indeed 6D. Every thing that I know goes by the pin with the black pulse dot. Pin one and two continuity beep ok
Which pin will be AC1 Pin with pulse dot?
kbyrne
Joined Dec 10, 2011
93
28.09ACV measured each side of transformer after pin 1 & 4 connected then pins 2 & 5 connected. Mains to pin 1
other mains to pin 5. Secondary side AC1 pin 6, GND pin 8 and AC2 pin 10 if I understand all of this you have stated. 28VAC times 1.414 = 39.59DC both sides of rails. Why only 36DC? Filter cap size? Mains measure 117.3ACV.
kbyrne
Joined Dec 10, 2011
93
Old power supply board still working. Circuit needed 1 Amp per rail. Filter cap is 4700uf @ 50VDC . 36VDC is with a transformer 24VAC at two Amps. Miss print up above post, sorry. I have two transformers in mind one 48VCT center tap and one 24VAC. 24VAC is not center taped.
