Hammond-Suzuki XB-2 organ - problem on digital mainboard
WattPusher
Joined Mar 24, 2014
8
Hello -
I'm trying to diagnose a problem with a Hammond-Suzuki XB-2 organ - the first of the digital Hammonds from the early 1990s.
It's based around an M37700MZ microcontroller but the digital audio generation is handled by something called a "MUSE" chip and there's another chip from the same manufacturer associated with it called a "DRB" chip. The DRB chip is connected to a ROM chip by 18 address lines and 16 data lines. The least significant few bits of the address lines count up incrementally which leads me to believe that this ROM chip holds one or (more likely) more wavetables. The MUSE chip has a serial data out line that goes to an LC7881 DAC.
To crudely describe what's supposed to happen, the M37700 reads the keyboard and the ADC-encoded positions of nine "drawbar" potentiometers; each drawbar corresponds to a roughly sinusoidal overtone, the sum of which becomes the output of each key depressed. What's coming out of the DAC instead of that is a badly-distorted squarewave-like tone with some nasty enharmonic spikyness mixed in. Especially noteworthy about that is that the position of the drawbars has absolutely no effect on the output. I know the microcontroller is reading them properly because their positions are being accurately indicated on the LCD display on the XB-2's control panel.
Another noteworthy observation is that the nasty tone increases in pitch from the left end of the keyboard up like you'd sort of expect but when you get to the C above middle C, the pitch repeats that of middle C and the same pattern repeats all the way up to the right; it's the same octave repeated over and over.
The power supply as delivered to the board is a solid +5V with no ripple. I've been able to scope the data going into the DAC and it looks reasonable although I don't have a good way to decode the numbers; at this point I don't have any reason to suspect that the DAC isn't putting out in analog exactly what it's getting in digital because even if the DAC were dropping a bit or something, drawbar movement should still change the sound. This has left me poking around the board for digital problems and the one thing I've found that's really suspect is the data output of the ROM that's connected to the DRB chip. Here's what a single-trigger capture of a data line looks like:
Now, is there any ROM chip in the world that would have a data line trace looking like this normally? There's nothing on the data bus between the ROM and the DRB chip except for a couple of eight-piece pull-up resistor arrays. The ROM in question is in the upper right of this schematic page:
Anyone have any thoughts for me? My understanding is that these three chips are bespoke to the XB-2 and if they break (and they're known to from time to time) there's nothing to be done other than the salvage route (to either fix or part out) so you can probably understand that I'm keen to rule out anything and everything else on the mainboard best I can.
35,321
While the data signal as seen on the oscilloscope may look strange, it appears to me as a valid logic signal.
There are definite logic LOW and HIGH levels (0V and 5V).
The spikes are likely as a result of changes in the address bus.
The slow rise before the HI signal indicates that the ROM was deselected and the data outputs are going into a high impedance state. This is normal.
WattPusher
Joined Mar 24, 2014
8
OK, I appreciate the info. It is the case that there is some sort of enable line that's coming out of the DRB chip and going into pins 2 (not-"CE" - chip enable?) and 20 (not-"OE" - output enable?) on the ROM chip. Here, the top (yellow) trace is that enable line and the bottom (blue) trace is one of the data output lines:
I don't necessarily need to understand what's going on between the two but it's not making a lot of sense to me. But there was something else I noticed. The DRB chip's pin 100 is being driven by a Kyocera clock module operating at 20MHz (albeit through an inverter marked "AC 04" on the schematic that I haven't been able to locate and that I'm not sure is actually on the board, which is supported by what I'm about to show you). Here's how that looks on the scope; the center horizontal line is 0V:
Here's the applicable part of the clock oscillator's datasheet:
The scope shows a DC offset (see measurements along the bottom of the trace frame) that doesn't really match the shape of the output wave as described in the datasheet; the scope is showing about twice the voltage values as the datasheet. But more concerning, the datasheet says the output should have a max rise/fall time of 5ns but the scope shows it to be about 30ns (20MHz waveform on a 50MHz scope, btw). I was putting the probe on a test point right outside pin 127 of the MUSE chip. Both the MUSE and DRB chips need this clock so if it's not functioning correctly I can't imagine the organ playing as it should.
35,321
Your oscilloscope's bandwidth is 50MHz.
Don't expect much fidelity when viewing a 20MHz square wave.
The first overtone (2nd harmonic) will be 60MHz. The scope has already lost that.
The 3rd harmonic is 100MHz. You need an oscilloscope with at least 100MHz bandwidth to start seeing something that resembles a square wave.
WattPusher
Joined Mar 24, 2014
8
Ah, I see - thank you.
I feel like the repeating upper octave and the lack of drawbar effect ought to lead me right to the problem if I can just discern the operating theory of the mainboard by inspection; the service manual isn't very forthcoming (unlike, say, the Polymoog 203A's which came in a big three-ring binder).
