Hi everyone,
my name is Andrea, and I'm an electronic engineer.
I'm trying to develop a Hall Effect sensor interface, to a 0-24V digital electronic device.
I'm using two different Hall Sensors: AH175 and a TLE4935.
The sensor setup is more or less the same, the one with the AH175 has a series resistance on the Output, the TLE hasn't.
I designed an Opamp circuit which brings this square wave with an amplitude of 0-10V, to a signal 0-24V.
This signal, once converted to the 24V, goes into a different line, which is 0-5 V, through a optocoupler.
When I link the AH sensor, everything works fine, but, when I connect the TLE sensor I see a strange behavior on the OpAmp output:
Can you please help me?!
I don't know how it behaves this way.
Thank you very much!
Andrea
Andrea
