hall sensor HW101A
bertus
Joined Apr 5, 2008
22,925
The shown sensor is a bare hall element in bridge configuration.
It will work like the ancient KMZ10, of wich I will attach an application note.
Keep in mind that the exitation voltage is 2 Volts max.
Bertus
alone
Joined Jan 9, 2019
Bertus
so both of them are similar
tnx sir
bertus
Joined Apr 5, 2008
22,925
As said, the exitation voltage of the HW101 is 2 Volts max.
The KMZ10 has an exitation voltage between 5 and 12 Volts.
The working principe is the same.
Bertus
