i have removed the 1k resistor from postive to the collector on the first transistor and i have connected up a wire from the collector to ground .
the transistor turns off
I will be around when you are ready to jump back into the effort.i am thinking. my coil is 26 gauge wire but i have a lot off turns on it about 1500 to 3000 turns. and it is an air coil which really does not help. i may have to make a smaller coil i will have to go back in to my room off tricks and make a new coil. if you do not mind waiting a few days i hope to build a new coil with a iron core this time.. i must thank you for all of your kind help, and i hope to show you my pulse motor works its true magic as soon as possible A real gentle , thanks againman
Holy cow, that's a lot of wire!i am thinking. my coil is 26 gauge wire but i have a lot off turns on it about 1500 to 3000 turns. and it is an air coil which really does not help. i may have to make a smaller coil i will have to go back in to my room off tricks and make a new coil. if you do not mind waiting a few days i hope to build a new coil with a iron core this time.. i must thank you for all of your kind help, and i hope to show you my pulse motor works its true magic as soon as possible , thanks again
