half wave rectifier
Potwes
Joined Aug 30, 2016
in a half wave rectifier,the turns ratio of the transformer is N/N=31:2,the primary of the transformer is connected to power mains 22V, 50Hz. the dynamic forward resistance of the diode used is 20 ohms and the load resistance is 1 kilo ohms.if the threshold voltage of the diode is 0.66 volts. Determine
(a)the average current through the load.
(b)the rectification efficiency.
(c)the peak inverse voltage.
ericgibbs
Joined Jan 29, 2010
8,583
hi,
OK.
Can you post your calculations, so that we can check your results.?
eg: with that transformer ratio, what do you calculate for the transformer secondary voltage.?
E
