Hi all!
I'm working on a project, I have a pressure sensor with a -50mv to +50mv output, I have 2 AD8666 op amps set up, one inverting one non inverting, what sort of diodes should I use on the outputs for half wave rectification?
I've looked all over google and the forums and all they say is diode..
Gain is 40 btw, I want the output from the non inverting to be 0V to 2V when the pressure sensor is 0 to 50mv and the output from the inverting to be 0 to 2V when sensor is 0 to -50mv
(Both op amps are set up correctly and working, it's just the half wave rectifiers..)
Thanks!
Thanks!
