Hacking an IR RGB light to fit a Controller.
Nikita Gaidouk
Joined Oct 21, 2015
3
I bought an RBG light off e-bay which has an IR (Infra red controller) in the board and only 2 wires coming out (12V Power + & -)
Now I would like to connect that light to an RGB controller which has 4 outputs (Power, Red, Green and Blue)
After Opening the light this is what I found:
* please know that the diagram is my best guess.
So my question is this:
Can I just simply disconnect the "Negative Wire" and add the 3 separate RGB's like so:
Or should I disconnect the circuit board as it won't be needed?
Example of what I want to do:
LINKS:
RGB LIGHTS: http://www.ebay.co.uk/itm/351213133...49&var=620396205632&ssPageName=STRK:MEBIDX:IT
RGB CONTROLLER: http://www.ebay.co.uk/itm/261925665...49&var=560752383493&ssPageName=STRK:MEBIDX:IT
Dodgydave
Joined Jun 22, 2012
11,304
No, the rgb leds need a dc supply and a control voltage pin for each led, the controller you have is for Negative voltage control to each led with a positive common.
