I know this is an old thread but I have a similar issue with a slightly different treadmill control board. Its an Aerobics Inc. 9501001 rev f from a pacemaster pro plus treadmill. I do have the upper panel and it works fine, just not ideal for operating a lathe. The upper and lower boards are connected with an rj45 connection with, I believe, 8 fine wires. I would like to simplify the motor control with a simple dial That does not need the speed to be reentered each time the session is paused. unlike others I’ve seen, this control board has no obvious labeling for speed control. One thing I tried was to make up a test set of wires with an rj45 connector, plugging it in instead of the connection from the upper panel. One wire indicates 5 volts when tested to any of the other wires. One tests as ground.
4 of the wires will elicit clicking sounds from the control board if i connect them with a double a battery. On one occasion the motor started when 2 of the wires had the double a battery connection, but I couldn’t get that response again. Everything still works fine it I reconnect it to the upper controls. I can solder ok but am not well versed in electronics. Appreciate any insights anyone can provide.
Moderator edit: New thread created from this.
