Dear AAC,
Hoping to maybe find some tips on hacking an LED light bar. It comes with a built-in gesture switch (IR LED + IR receiver: place your hand in front to turn it on, kind of thing). The default position is "off", and it needs the gesture input to turn it on every time after receiving external power. Due to the location that I'm planning to mount it, I'd much rather have it just come on by default as soon as it receives external power (controlled via an external light switch).
The PCB looks really simple, but it's beyond my abilities. I'm guessing the right side is the power electronics driving the LEDs, and the left side is the logic controller for the on/off mechanism. The white wires are the "in" from the power brick. The red/black wires are the "out" to the LEDs.
On a wild hunch based on the only thing on here that looked like a transistor, I found that connecting V+ to the bottom contact of R7 triggers the on/off switch behavior.
That's basically all the info I have. If anyone has any thoughts on how to force the LEDs to "on", would really appreciate your advice!!
Cheers
D
Cheers
D
