Guitar amp hum no signal
Ylli
Joined Nov 13, 2015
1,092
Wow, that is quite a bit of peaking. Didn't run across that info in my quick search. Interesting. I've become a 'Local Live Music' fan and am slowly assimilating some of the technical info.
Audioguru again
Joined Oct 21, 2019
6,826
A typical guitar speaker has a frequency response worse than a lousy old AM radio or telephone.
A typical 50 years old man also has a poor hearing's frequency response.
I am 78 years old and my hearing aids work fine with a high frequency peak that is more than +60dB.
Audioguru again
Joined Oct 21, 2019
6,826
ok. op amp arrived.
measured: -0.036 .
Audio measurements are at a certain frequency and the voltage level should be "peak" so that your oscilloscope can show when the amplifier output is clipping with extreme distortion.
An ordinary multimeter usually measures the levels of only 50Hz and 60Hz electrical sinewaves accurately. It does not show amplifier clipping.
Then your 0.036 number has no meaning.
BobTPH
Joined Jun 5, 2013
11,678
I don’t think @MrChips was asking for a DC voltage measurement after the opamp, he was asking you to use your signal tracer (amplified speaker + capacitor gadget) to see if the signal makes it there. And, as always, you need to strum the guitar while doing so.
Rabbitbreth
Joined Jan 22, 2019
188
oh yeh!!! ooops .. too much time in between . thanks for that
Rabbitbreth
Joined Jan 22, 2019
188
so . have done the right test . I'm back ... I'm focused . so I have a strong signal coming through the powered speaker now . faint hiss in the back ground .
35,322
As Bob says, the acid test is getting proper sound out of the loudspeaker.
If no joy, go back and do the test on post #128.
Rabbitbreth
Joined Jan 22, 2019
188
Okay, so that opamp was bad. I would connect the speaker back to the amp, it might just be fixed.
hooked up amp speaker and Im still getting white noise but the guitar signal seems a bit louder than before . does that make sense ? on to the next op amp ???
35,322
You never mentioned anything about the guitar signal in previous tests.
Go back and do the test from post #128.
Rabbitbreth
Joined Jan 22, 2019
188
I hook up the powered speaker and play a string ...that's what I'm calling the signal ,right ? Have just done this test on no. 128 and there is no signal , no hiss . nada.
35,322
You have four remaining uA741CP op-amps to check.
The pinout of uA741 and TL071 are the same. The output signal is on pin-6. Try to probe the signal at pin-6 without shorting to any adjacent pin.
Rabbitbreth
Joined Jan 22, 2019
188
ok . powered speaker test : one lead on GND .. and other lead/probe on pin 6 of each op amp . yes ?
so.. on the pic above . pin 6 would be, top pins 3rd from the left . ?
35,322
Yes.
Let us identify the op-amps #1 to #5 starting from the left. Describe what you hear from the PC speaker while probing pin-6 and playing the guitar or bass. Get an extra pair of hands if you need it. Shorting pin-6 to another pin will be disastrous.
(I am going to be on the road for the next three days. You may want to start replacing each op-amp one at a time.)
Rabbitbreth
Joined Jan 22, 2019
188
Yes.
OK . thanks for that . will be careful with my probe . safe travels ...going anywhere exciting ?
so #1 have signal .
#2 , 3#, # 4 , #5 all no signal.
will begin replacing # 2 next ... then test and move on
