Guitar amp hum no signal
Rabbitbreth
Joined Jan 22, 2019
188
You can salvage or sacrifice an audio cable or you can buy a 3.5mm plug or jack as required.
You can do whatever works for you.
There is no need to connect both LEFT and RIGHT channels. MONO will work just as well.
If your powered speaker has a cable with a male 3.5mm plug, then get a mating 3.5mm jack.
If the speaker has female 3.5mm jack, then get a connecting cable or sacrifice a spare cable.
You can omit the plug and jack if you want to sacrifice an old cable. Just cut off the plug at the end of the cable and solder the wire directly to one leg of the capacitor .
One leg of the capacitor is your test probe. The other leg of the capacitor goes to the left or right input channel of the speaker. The capacitor is in series with the input to block DC. Polarity of the capacitor is not important. The GND is brought out to connect to the GND of your guitar amp.
ah that is wonderful mate . thank you !!!
35,157
To be honest, the powered speaker very likely has DC blocking capacitors already installed as part of the input circuit. We would not know for sure unless we checked. Adding an external DC blocking capacitor does no harm.
Rabbitbreth
Joined Jan 22, 2019
188
so what 's my first port of call with my new probe ? was thinking about those diodes I snipped and resolded .
35,157
No. The speaker probe will be used to search for music content.
Your first stop is to measure DC supply voltages. For that you will use your DMM. You will take two readings with your DMM.
Test #1
Connect DMM black lead to GND. Connect DMM red lead to Test Point 1.
Test #2
Connect DMM black lead to GND. Connect DMM red lead to Test Point 2.
Rabbitbreth
Joined Jan 22, 2019
188
Test #1
Test #2
ok .
1: 14.1
2: 14.9
35,157
Here is your first signal test point.
Connect the GND from the speaker test probe to the same GND as in post #124.
Connect the capacitor test probe to the point indicated by the RED arrow above.
Connect your guitar to the Torque Acoustic amp. Adjust all volume controls (on guitar, amp, tone, speaker amp, etc.) until you can hear adequate sound coming out of the PC powered speaker.
Rabbitbreth
Joined Jan 22, 2019
188
low hiss through powered speaker . same kinda white noise as amp speaker
sarahMCML
Joined May 11, 2019
703
There's a burnt resistor just above the Red arrow!
35,157
Here is your next test point.
GND connection will remain the same in future.
(I hope that you are playing the guitar for all tests and the guitar volume is set to maximum.)
35,157
Remove the first uA741CP as shown in post #132.
Install an 8-pin DIP socket.
Insert TL071CP, paying attention to the chip orientation.
Repeat the signal test as per post #132.
