GSM amplifier circuit
Status
Not open for further replies.
amre
Joined Dec 29, 2015
4
Hello
i want to design an amplifier to radiate a 950-1800 mhz signal from my source in 150 meter radius or more than that
i don`t know where to start
if any one help me with this i`ll be very grateful
Thank you
amre
Joined Dec 29, 2015
4
well it`s for jamming circuit that radiate 30 meter maximum
i want a separate circuit that feed from the rf section and amplify the signal so that it cover larger area
Thanks
amre
Joined Dec 29, 2015
4
it`s for studying purpose
what i`m missing is the gain
it`s not designed for jamming as it`s designed for securing specific radius
so 30 meter will be not enough
the BW 925-970 && 1785-1900 MHZ
Those are the frequicy range
amre
Joined Dec 29, 2015
4
ok
the if section is finished which i used 555 timer+ lm386 to lm 741 which is the o/p to the rf section
signal from if go to rf will pass through 2 vco (925-970 vco) & (1785-1900 vco)
the o/p of each vco goes to mosfet then the o/p of each mosfet goes to antenna
or to a separate unit to amplify the signal with it`s own power supply if it`s possible
bertus
Joined Apr 5, 2008
22,278
We do NOT allow jamming devices over here:
Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
Status
