Ground pin Variable resistor?
ekremgusani
Joined Mar 20, 2011
157
Where do I connect the ground pin of variable resistor, to the any metal part of project box or to the negative power connection?E9847D82-2988-45CF-B541-3A95A74B3CB5.jpeg
34,809
If you are using a 3-terminal potentiometer (volume control) as a variable resistor, there is no GND connection.
General practice is to wire the center tab to one of the end tabs for reasons of reliability.
34,809
This is a typical noobie question I get asked:
"How do I connect power and GND to the pot to turn it into a variable resistor?"
27,511
Based on the notations that I see in the post, the intention is to use it as a potentiometer to provide a variable voltage. So the terminal marked "ground" should instead be marked as "common", meaning common to both the voltage source and the signal connection. On some occasions "common" and "ground" are connected, but mostly that is not the case. "Ground" is, in theory, an large plain of zero voltage and zero impedance. Mostly it exists in textbooks.
