Graph the output waveform of a MOSFET circuit
akkex eliu
Joined Jul 21, 2018
Hello, I am new in this...
Here I have to graph the output waveform of the circuit for a square input wave, whose peak-to-peak voltage ensures Q2 is polarized in the ohmic region.
Suppose Q2 has RDS (on) = 9Ω and Q1 RD = 8kΩ
please I just need the graph, if someone can simulate in proteus or another simulator and take a photo
i will apreciate to lot it
MrAl
Joined Jun 17, 2014
13,872
You should really attempt this yourself first. That's the way this forum usually works. That way people have a better idea what you want. If you dont know how to use a simulator you should learn because it is well worth it. LT Spice is one such free simulator. You will not be sorry that you had learned this kind of software.
dl324
Joined Mar 30, 2015
18,507
You'll learn more if you show us your attempt at a solution so we can see where you're going wrong.
Circuit simulators have their place, but you shouldn't depend on them until you have a better grasp of fundamentals. I liken it to using a calculator before you know how to do the calculations manually.
