good solid analog way to do pulse level shifting
Ian0
Joined Aug 7, 2020
13,249
Ok so this is not a linear amplifier but the opamp acts as a comparator outputing the power rails?
How can I know that its outputs are saturated in this situation?
No, that’s a linear amplifier. Try inputting a triangular pulse and see what it does.
You can guess that because it has negative feedback.
0V in gives -6V out and 5V in gives -2V out, which wasn’t exactly the spec.
yef smith
Joined Aug 2, 2020
1,479
Hello Eric in post 24 I showed the full math I tried to develop your circuit.
Could you see where did I go wrong?
Thanks.
Ian0
Joined Aug 7, 2020
13,249
I would be interested in knowing what he is driving with -Vout, also the pulse Period and Required Rise fall times.??
E
Absolutely. A general observation on pulse waveforms: The amplitude is rarely a critical parameter. Of more importance are the repetition rate, pulse width and rise and fall times.
ericgibbs
Joined Jan 29, 2010
21,555
hi yef,
E
yef smith
Joined Aug 2, 2020
1,479
Hello Eric,basickally its just educational question.
but I want to do 20ns rise and fall time.pulse period 100us.
-Vout is the negative rail? its -8V
Where did I go wrong in the mathematical way of post 24?
WBahn
Joined Mar 31, 2012
33,122
Hello, currently I am using a this very long circuit to convert a 0-5V pulse into -2 to -6V volt pulse.
Is there a a good circuit which I could learn how to effectivly shift the pulse levels?and coltrol the high and low levels, while keeping the pulses rise and fall time?
As usual, you don't give the important details. How short are these pulses? What is the repetition rate (or, if not periodic, what is the closest that two pulses can occur to each other)? What is the pulse duration? What are the rise and fall times? How close do the output rise/fall times need to match the input rise/fall times? Since the amplitude of the input pulses is different than the output pulses, what is the definition of rise and fall time that you are using?
38,746
In post #24:
First calculate the volage at the op amp (+) input.
Then using that voltage for the (-) input, calculate the current through R3, which, due to negative feedback, must equal the current through R2.
From that you can calculate the output voltage.
WBahn
Joined Mar 31, 2012
33,122
A 20 ns rise and fall time is very fast. Again -- what is the definition of "rise time"? Is it 10%-to-90%? Is it time constant? Is it something else?
If the output is going 80% of the distance between -2 V and -6 V, in 20 ns, that's 3.2 V / 20 ns = 160 V/µs. That's pretty fast, but today there are a number of options that can do that.
yef smith
Joined Aug 2, 2020
1,479
it will be great to know one way you could reccomend ?
" If the output is going 80% of the distance between -2 V and -6 V, in 20 ns, that's 3.2 V / 20 ns = 160 V/µs. That's pretty fast, but today there are a number of options that can do that."
WBahn
Joined Mar 31, 2012
33,122
Hello Eric, I tried to analize your circuit to get mathematical formula Vout=F(Vin)
I used the virtual ground assumption of V-=V+.
but its not working so much
I got in the end Vout=6V and Vin cancels.
Where did I go wrong in the mathematical logic?
Thanks.
It's not that hard.
V+ = 6 V + ((Vout - 6 V) / 2 kΩ)·(1 kΩ)
V- = Vin * 10 kΩ / (10 kΩ + 15 kΩ)
V+ = V-
Now just solve for Vout as a function of Vin.
V+ = 6 V + (Vout - 6 V) / 2
V+ = 6 V + Vout/2 - 3 V
V+ = 3 V + Vout/2
V- = Vin / 2.5
V+ = V-
3 V + Vout/2 = Vin / 2.5
Vout/2 = (Vin / 2.5) - 3 V
Vout = (Vin / 1.25) - 6 V
Vout = (4/5)Vin - 6 V
WBahn
Joined Mar 31, 2012
33,122
You haven't given anywhere near enough information to recommend a specific part. Go to DigiKey or some other similar site and use their product selectors to find suitable devices based your needs.
Or use one of the simpler circuits that have been suggested, being sure to find transistors that have the necessary bandwidth and sizing your resistors accordingly.
A lot will depend on what you are driving with this signal, which is yet something else that you've given no indication of.
yef smith
Joined Aug 2, 2020
1,479
Hello Wbahn, thank you very much .regarding solution in post 37 ,what is the limitation of this circuit.
seeing in digikey components Is choosing a black box.I only know the rise a fall and output pulse values requerment.
could you tell me an example for requirement and next level circuit that solves it so I could learn its inner logic?
Thanks.
Ian0
Joined Aug 7, 2020
13,249
The JFET circuit can manage 20ns with a J174 and lower resistor values. (About 60ns with the J177 and the resistors I drew) for a lot less money than an op-amp with the required slew-rate.
