MisterBill2
- Joined Jan 23, 2018
- 28,208
I know that some of them are now. The only one I ever had to deal with was an actual solenoid, two coils, lock and unlock, in a late sixties Plymouth. The motor and gear are probably a lot cheaper and much better at the task, no doubt. And certainly they will draw less current than the window motor and cam, and possibly drive hard enough to do the job. But a cam cocking a spring over a whole rotation can store up a whole lot more energy to launch the ball. So the challenge will be to know how much force for what distance at what speed is required. Only three variables in the one equation. Should not be too bad.You do know that the lock"solenoid" I linked really is a motor operating a gear rack don't you. And it will take way less than a window opener motor.
