Generation of Pulse in LTspice
ericgibbs
Joined Jan 29, 2010
21,572
hi mo,
You have the pulse model I posted #9, use the method described by papa in post #23, to inject that pulse.
Do you know how to do that.?
Also, we need the lib.txt file for the component parameters.
E
mohtishamali
Joined Jul 9, 2021
55
hi mo,
E
actually i am still not sure how to do it as i did not understood fully. The problem with me is that i am new in LTSpice and i am not fully aware with how to use different functional blocks in LTspice.
mohtishamali
Joined Jul 9, 2021
55
hi mo,
That lib file includes unused models, modified to lib2.txt
You can try these two idea's.
What does your circuit represent.?
E
Hi eric,
its for an inverter driving a motor.
The issue with your pulse is that the duration of transient should me 10ms but the pulse you generated, its 20ms. I tried to reduce it but then the overshoot goes beyond 1100V. Can you pls assist how to fix that?
