Generation of multiple phases out of an incoming clock
Manish Chowdhary
Joined Jul 29, 2017
10
I seek help in understanding a phase generator circuit. This circuit creates 64 phases of the 100MHz input clock each separated by 156.25ps.
Effectively it is creating an output of 6.4GHz from the incoming 100MHz.
I am wondering how the output will look like
1) What would be the output like, will it be a continuous signal with time period of 156.25 ps? (as I have shown in the attachment)
2) What circuit elements are required to generate phases out of an incoming signal?
Thanks in advance,
Manish
Papabravo
Joined Feb 24, 2006
22,058
The normal method of generating higher frequencies from a lower frequency reference signal is to use a phase locked loop. This technique is well known, understood and documented. Once you have the high frequency signal you can divide it down to get precise phase delays. For example you can use two filp-flops to make quadrature clocks with 90° of delay between the edges.
ronsimpson
Joined Oct 7, 2019
4,647
The outputs are all at 100mhz. Each is shifted 156pS.
Phase shift oscillator.
I have built the same thing but with many LCs as the delay.
Inside a IC you can have very fast inverters. (150nS delay each) In your case use 64 inverters in a loop. The loop will oscillate. The delay is very related to the supply voltage. I varied the supply voltage of that part of the IC to change the frequency. In your case 100mhz. Now each inverter has 100mhz with a phase shift of 156nS * X. x=1 to 64ghz you are looking for.
edited:
It you XOR and the outputs you will get the
Deleted member 115935
Joined Dec 31, 1969
Thanks in advance,
Manish
can you draw us a circuit please,
my understanding of what your saying is that you end up with 64, 100 MHz clocks,
is that what you want ?
Papabravo
Joined Feb 24, 2006
22,058
I think he wants a 6.4 GHz. clock from a 100 MHz. Reference, and he wants 64 clocks with small phase offsets from each other.
Delta Prime
Joined Nov 15, 2019
1,311
hello there :)
This is out of Blue Sky , only because I do not know your criteria.
T straight forward
The ALTLVDS_RX megafunction provides a limited drop-down list selection for setting the clock and data relationship in non-DPA mode. The parameter is What is the phase alignment of 'rx_in' with respect to 'rx_inclock'. By setting this parameter, the ALTLVDS_RX megafunction calculates the proper capture phase for the serial data.
The phase shift values are based on the rx_inclock period, which can vary depending on your interface. The following are common rx_inclock usage scenarios
I can only think of one example I can possibly steer you in the right direction.
input clock phase shift for capturing data in the ALTLVDS_RX megafunction
The total possible number of capture phase positions depends on the deserialization factor of the interface. For each serial bit period, there are 8 phases available from the fast clock. The fast clock operates at the serial bit rate
if you wish to specify the rising edge of rx_inclock to be center aligned on the third serial bit of the 8 bit word, you would need a total of 20 phase shift increments (8 phase increments for each of the first two bit periods, plus 4 phase increments for the center aligned rising edge in the third bit period).
The fast clock operates at 800 MHz, the same as the data rate. The fast clock period is 1.25 ns, which results in 156.25 ps per phase shift increment. The total required phase shift in this example to describe the input clock and data relationship is 20 * 156.25 ps = 3.125 ns.
Once you calculate the desired phase shift value, enter it in the ALTLVDS_RX variation file
Manish Chowdhary
Joined Jul 29, 2017
10
Not sure if I explained it correctly earlier, let me try to clarify
Let us say we have a 'X' MHz clock and we need to have 'Y' phases of this clock each separated by time period 'T'.
What is required to achieve this?
1. I think we require a reference clock with time-period 'T', such that. Y * T == Time period of 'X' ( in appropriate units)
2. A phase generator circuit.
What would be simplest way to achieve the same.
Manish Chowdhary
Joined Jul 29, 2017
10
edited:
View attachment 214603View attachment 214604
Thanks for the explanation, however, what if someone wants a different phase shift?
Your solution seems to depend on the speed of the inverter which is near to 156 nS.
And also the inverters might not give a precise delay each time. Can we improve this solution?
ronsimpson
Joined Oct 7, 2019
4,647
What we do is have a 100mhz crystal that we know is good.
We also have a not accurate 100mhz ring oscillator using 64 inverters. Its frequency can be changed with the supply voltage.
Next use a PLL to compare 100mhz reference and 100mhz ring or phase shift oscillator. The PLL then controls the oscillator to bring it to the right frequency. The PLL compensates for inverter.
Ramussons
Joined May 3, 2013
1,567
There is no guarantee that each of the 64 inverters will have the same delay.
