How can make three terminal supply that will have common ground and one will give +12v and other will be -12v.
i have DC sources +12v i want to use it and current 500mA for bothWhat will you be starting with? For example, will your source be DC or AC? What voltage(s) are available? How much current do you need for your + supply and - supply?
That source must be able to deliver over an amp if you want 500mA for both outputs.i have DC sources +12v
by Jake Hertz
by Aaron Carman
by Jeff Child
