Generate RFI by Rectifier
micropad
Joined Dec 24, 2011
109
As per the above circuit , When Capacitor voltage exceed the transformer output voltage (12V) ,Then Diode is reversed bios ,This can be happen fast , So in this case . Is it possible to generate RFI
Please advice
ericgibbs
Joined Jan 29, 2010
21,552
hi micro,
That type of circuit can generate RFI on pulsed forward conduction of the diodes, also during reverse storage time of the diodes.
Do you have a particular PSU that is causing a problem.?
E
micropad
Joined Dec 24, 2011
109
hi micro,
E
No
I am going to make it for supply power to simple IoT project , I am Using ESP-12E
