No. Where did you come up with that number.Mabuchi RS-555PH-3255 has a rated voltage of 12 volts and full-load current of 2.4 amps and a stall current of 11.8 amps, does that mean it can generate 132 watts?
Power = voltage x current. So how do i calculate maximum output power based on current and voltage?No. Where did you come up with that number.
A motor does not output power, it consumes power. Why do you seem to be confused on this point?I mean how do you calculate maximum possible power output in watts, based on current and voltage?
You don't have enough information.A motor can be operated above full load current. 10 amps is less than the stall current, which is 11.8 amps. I know if you operate it above full load current, it'll overheat and possibly damage the motor, but i am trying to calculate maximum possible power output.
I believe you already have the answer, the full-load current times the voltage. Of course it depends on how the manufacturer defines "full-load" but if it was me, I'd pick the point where the output is maximized. If you load the motor to where it is drawing more than the full-load current, the rpm will drop and you'll actually get less shaft work out of it. Like shifting your car into too high a gear while under load. Lots of load on the engine, but not enough rpm.I mean how do you calculate maximum possible power output in watts, based on current and voltage?
Tell that to the battery, it doesn’t seem to know that. When I stall my motor, the battery runs down faster!So in fact the V is really the back emf of the motor.
At stall the back emf is zero. So at stall the motor consumes zero watts
| Thread starter | Similar threads | Forum | Replies | Date |
Why can't I generate the (TpLH/TpHL)*Skew graph? | Homework Help | 0 | |
AI Generated Content | Feedback and Suggestions | 9 | |
| R | Electromagnet Turns And Same Field generated?? | General Electronics Chat | 5 |
