But it doesn't include a crystal. Isn't it?Use an LVTTL IC with inverting amplifiers in it, like a quad NAND.
Can you explain bit more?use crystal oscillator then run the signal through gate with Schmidt trigger. it will square it even if input was sine wave. if you want 50% duty cycle, add flipflop. there is tons of circuits that produce signal you require. if the frequency need some adjustment, use PLL chip.
All the circuits are designed for TTL devices instead of LVTTL. The previous one which is designed for TTL is didn't work with LVTTL. (refer the previous post). Will these circuits work with LVTTL?
Use a CD4069 chip it will work on 3 v, or use a a LVTTLAll the circuits are designed for TTL devices instead of LVTTL. The previous one which is designed for TTL is didn't work with LVTTL. (refer the previous post). Will these circuits work with LVTTL?
Guys!! Any Idea please?
Will those designs work with the NOT gates implemented on a FPGA which has LVTTL?Use a CD4069 chip it will work on 3 v, or use a a LVTTL
As i have never worked on FPGA's , i cant give you an answer, i can only assume if they have inverter gates separate to the chip, they may work, try it and find out.Will those designs work with the NOT gates implemented on a FPGA which has LVTTL?
by Jeff Child
