MisterBill2
- Joined Jan 23, 2018
- 28,197
Not specified is if the desired 16 to 20 amps is AC or DC, and that makes a lot of difference. And it also depends on how you define "Massive". But the short answer is "YES".Is there any way to generate 24v 16-20 amps from a wall socket, besides a massive transformer?
Of course a good transformer is by far the more efficient method, better than 90%, usually much better, which is easily shown by the minimal temperature rise of a good quality transformer working at full load. An AC powered High efficiency switchmode inverter is the lighter way, but a good one will cost more than the good transformer.
If the power is to be DC, then the answer is still yes, but now a switching mode power supply is required.
