- Joined Jan 23, 2018
- 28,552
INPUT connections on IC devices should have proper termination, outputs not used should normally be open. Proper termination is either a zero or a one, for digital ICs. That varies with the technology and the device. For analog ICs look on the manufacturers data sheet, because it does matter.Outputs are not the concern. What magic makes you think they are?
As for the regulator, some survive Vout > Vin; some don't. Understand the datasheet.
