Hydraulic Engineering question: Which plan is better?
B-JoJo-S
Joined Jan 3, 2026
600
I'm planning on capturing rain water in these barrels. There will be four barrels in all, each in groups of two. The drawing shows two rain barrels supported one above the other. At the top are the rain gutter downspouts. At first rainfall water flows into the weeping tube. That tube has a number of weep holes that allow the water to drain out. This catches the dirtiest of the water coming from the roof. The pipe diameter is 2 inch. I may have to upgrade the weeping pipe to something big enough to collect more dirty water before the water starts flowing into the barrels. • • • As the weeping pipe fills, water begins to flow past the valve and is directed into the two barrels. The bottom barrel does not have a vent, so air will want to flow back against the falling rain water. I don't imagine - and here's the reason for my question - trapped air - I believe - will seek to flow up into the upper barrel. Once the bottom barrel has filled to capacity the upper barrel, which may already have some water in it, begins to fill to capacity. Once both barrels are full and all the air has bled out of the barrels any further rainfall will go down the overflow pipe.
MY QUESTION(s): Will having two vents (right drawing) work better? Or will the left barrels be sufficient to fill them? I'm just not sure air will be able to exit quickly enough to allow the bottom barrel to fill while the rain continues to fall.
As for the vents, they will be stuffed with copper mesh to keep bugs out. If I have left over PVC I'll make longer bug filters.
This water is not intended for drinking. Although in times of emergency, water can be filtered and boiled before consuming.
I have only two barrels set up at present. They stand on end. To get water out I have to start a siphon. Once flowing the water flows somewhat slowly, but it flows. I can empty a barrel in about 10 to 15 minutes just using a siphon flow. You can ignore the stands, it was easier to screen grab them along with the barrels than it would have been to crop them out. Finally, at the bottom of the bottom barrel is a small hose bib so I can attach a hose to it. I don't have a pump yet but I intend to. Having the barrels on their side makes getting water out easy.
The construction is some pipes are glued together, others are fit together and held in place using self tapping screws. There's two Unions so the pipes can be disassembled and the barrels removed for cleaning.
B-JoJo-S
Joined Jan 3, 2026
600
Current configuration:
At the bottom of the weeping pipe is a cap with weep holes. That's the arrow at the bottom.
The Tee at the top of the 3/4" pipe gets a plug. When I remove the plug I can pour water into the pipe, thus filling the whole assembly with water. Plug off the top and the 3/4" pipe is ready to siphon. At the bottom of the pipe inside the barrel is a one way check valve. It HAD a spring in it but I had to remove that so the water could flow. That's probably a fairly big part of the reason why it takes 10 to 15 minutes to empty the barrel; the water flow is restricted somewhat.
EDIT: BTW; the drawings are dimensionally correct.
ronsimpson
Joined Oct 7, 2019
4,858
I think you need a vent at the top of the storage tank like in post #1. The air needs a way out or the tank will not fill fast. For every drop of water going in needs that much air to exit. If the water going in and the air going out are in the same pipe there will be a fight. Then as you pull water out the tank needs a source of air to fill the tank.
I do not know if you need a second vert like on post #1 right.
B-JoJo-S
Joined Jan 3, 2026
600
Thanks Ron. The current configuration seems to work well enough. One good rainstorm can fill that barrel in a few hours. It's not vented, so apparently air is still able to escape while the barrel fills. I just hadn't thought about it before now, hence, the reason for asking which might be better. The cost difference is a savings of one 2" Tee and replacing it with one 90˚ sweep elbow. Sweep elbow is as drawn whereas a standard elbow is a much sharper 90.
wayneh
Joined Sep 9, 2010
18,181
I don't think you really need piping for the topmost vent hole, although a bug/debris trap is a good idea. Since only air should be passing, the pipe can be much lower diameter.
Anyway my thought is that the incoming green pipe could enter the lower drum at any point, and the air could be piped separately out the top and into the upper drum, much as you have it drawn now. You'd have to make another hole in the lower drum for the water entry, and that's a downside, but I think separating the exiting air from the incoming water is a big plus.
Instead of a weeping pipe, I'd consider a screen or some other method to catch whatever debris you have. That would allow you to capture some water in even a slow rain, instead of losing it all out the weeping pipe. Success of separation technologies always depends on the nature of the debris. Something that works great for asphalt gravel might be useless against maple leaves. If it's working, go with it.
WBahn
Joined Mar 31, 2012
33,324
One simple way is to just bring the water into the bottom of the bottom barrel by putting a tee connection with the spout. The connect the top of the bottom barrel to the bottom of the top barrel. Done.
Also, be sure that you look into the laws regarding rainwater capture. If you live in an arid or semi-arid region, there are often water rights involved that results in some rather non-intuitive laws. These laws often place odd constraints one how the water can be collected, how much can be stored, and how it can be used. For instance, your system would require registration in Utah, because it consists of more than two barrels, you also can't store more than 100 gallons. Another common constraint is that collected rainwater must be used on the parcel where it was collected. In Colorado, the rainwater must be collected from the roof of the primary residence (it can't be collected from the roof of a shed or detached garage, or from a free-standing system), it cannot be used for drinking or any indoor use.
B-JoJo-S
Joined Jan 3, 2026
600
Local law: I can have up to two rain barrels without registering them. I could have more barrels, up to 250 EDIT: 2500 END EDIT gallons but they have to be registered. There is no charge for this but it must be registered if more than 2 barrels are used or if a 250 EDIT: 2500 END EDIT gallon container is utilized.
I will have to draw that to see how it looks. But thinking about it now - I think it should be better than anything I've considered so far. Thank you.
WBahn
Joined Mar 31, 2012
33,324
Local law: I can have up to two rain barrels without registering them. I could have more barrels, up to 250 gallons but they have to be registered. There is no charge for this but it must be registered if more than 2 barrels are used or if a 250 gallon container is utilized.
Are you in Utah? If so, I'm pretty sure that registered systems are allowed an aggregate of 2500 gallons.
But your system, per your original post, consists of four barrels. You should check with the authority in question whether two permanently interconnected barrels can be considered a single container. The rules are very arcane, so don't rely one what makes sense, because the rules seldom make much sense. For instance, in Colorado, what is the rationale for why I can collect water from the roof of an attached garage, but not from an unattached one?
B-JoJo-S
Joined Jan 3, 2026
600
OK, here's a redraw:
I've upped the weeping pipe to 4". It will gather four more times the dirty water before clean(er) water flows into the barrels. The bottom of the weeping pipe is a threaded connection to facilitate clean-out. I've also reduced the size of the vent pipe, since air moves more easily than water - as per @wayneh's comment:
I'll still put a bug screen in it. I have lots of copper mesh. Bought it back when Covid 19 was the latest and greatest scare. Was putting mesh into masks for a while.
If you're wondering why the Union between the two barrels it's because there's no way to separate the barrels if everything has been glued (except for threaded parts). The Union allows barrels to be disassembled.
As for the thought of considering two barrels together being thought of as one barrel - nah, if you know politicians - I'd be lucky if they didn't consider it 55 barrels (not gallons).
EDIT: The inverted P-trap at the top of the green pipe is to prevent dirty water from splashing into the Tee and going down into the barrels.
END EDIT.
wayneh
Joined Sep 9, 2010
18,181
Ah, I'm glad you understood my comments. Nice changes.
Now my only remaining concern is whether the whole arrangement can handle the complete flow typical of a strong thunderstorm. Now that I think about it, once the drums are full the overflow pipe alone has to handle it all. My downspouts sometimes gush at 5 to 20? gpm. That's maybe only once or twice a year but it's impressive when it happens.
B-JoJo-S
Joined Jan 3, 2026
600
The inverted P-trap at the top of the green pipe is to prevent dirty water from splashing into the Tee.
My downspouts are 2 x 3" sq. That's 6 square inches. A 2 inch pipe has 3 1/8ths square inches. OK, yeah, a heavy rain will be a problem. 3" piping would be 7 square inches. Good observation. Either that or make allowance for overflow.
cmartinez
Joined Jan 17, 2007
8,881
Why don't you just join the two stacked barrels top to bottom? instead of joining them on their sides?
Also, is the bottom barrel perfectly sealed at its top?
B-JoJo-S
Joined Jan 3, 2026
600
Each barrel has two 2" bungs. One is NPT the other is corse thread, but I can get an adapter for that. Stacking them one over the other would still require support between the two and would require even more plumbing. Later today I'm going to do a cost estimate of the materials. I'm expecting the cost to come in around $400. That doesn't include a pump, which is something I'd like to have. But gravity feed should be sufficient for most purposes.
As mentioned earlier capturing water is more for gardening than for drinking. If for drinking it would need to be filtered then boiled before drinking or cooking with. The BIG expense might be finding a 4" diameter pipe. 4" diameter, same length as a 2" diameter will hold four times more water. I'll do the calculations for how much water a 4" pipe would hold (and weep). That 4" pipe is not intended for any practical purposes other than taking the first of the rainfall from the roof away from the storage tanks. That will direct the dust and any bird droppings away from the tanks. For the most part - that is.
WBahn
Joined Mar 31, 2012
33,324
I'm guessing that these are the kinds of barrels that are completely sealed except for two NTP or Buttress fittings, such as this one:
B-JoJo-S
Joined Jan 3, 2026
600
Plus - stacking them would mean at some point I'd have to syphon the bottom barrel. On their side means no need for syphoning.
B-JoJo-S
Joined Jan 3, 2026
600
After estimating the amount of materials I've come up with a total cost (minus the barrels - I have those already). These are Lowe's pricing as of this morning. Note: The Groz Bunc Converter is through Amazon. Their price just went up from 21.01 to 30 dollars.
B-JoJo-S
Joined Jan 3, 2026
600
Makes me wonder why. However, that's before a 10% military discount at Lowe's and before taxes. Should be real close to $465.16.
cmartinez
Joined Jan 17, 2007
8,881
It seems that wood is your costlier material. Have you considered using sched 40 galvanized pipe for structural purposes instead?
B-JoJo-S
Joined Jan 3, 2026
600
No, I hadn't thought of that. What I like about wood construction is my plan to build cradles such as this:
The Oblique drawing at the top is a representation of how the pieces are assembled to form one cradle. There are two cradles per unit and there are two units for a total of four barrels (two barrels per unit).
Note: Hidden lines appear as solid lines in this rendition. My bad.
Well, I'm off to spend some money.
