gate driver hbridge to control dc motor
mah
Joined Mar 15, 2010
393
I do speed control on dc motor using PWM , I want to control it using two output from the controller. one output for pwm and the other for direction control.
I did this circuit in proteus but the motor speed is very low at high frequencies, I don't know what is the problem
18,172
Take a look at the switching waveform. You're probably getting incomplete switching at high frequency. You should specify what you mean by "high". What frequency is OK and when does it fall off?
mah
Joined Mar 15, 2010
393
frequencies below 1k hz is ok but higher than that slow down the motor in simulation.
I need it to work at 20khz ,24 Vcc
mah
Joined Mar 15, 2010
393
the output of ir2112 isnot pulses it is constant. but it gives pulses( max amplitude 5 volt) on th Hi ouput when I increase Vc pin 3 to 20 volt
