Full wave rectifier
manking4211
Joined Apr 30, 2014
15
Question
a) Figure 1 shows a full wave rectifier. Sketch the output voltage, v(t) with the labels of peak voltage and period. Assume all the diodes in the circuit are ideal.
b) Repeat part a if the diodes D3 and D4 are replaced by R3 and R4 respectively.
c) Repeat part a if the circuit shown in figure 2 is used. Assume the offset model is used for the diode with the offset voltage of 0.7V.
figure 1
figure 2
atferrari
Joined Jan 6, 2004
5,031
Question
figure 1
figure 2
OK, after re reading, I think I understood what I have to answer.
To whom should I sent my work?
Is it just a quiz? Any prize for the winner?
anhnha
Joined Apr 19, 2012
904
I am going to upload your answer here.
First, for part c, I think you are not completely right.
What is the output voltage as the input voltage is positive but less than 2*0.7 = 1.4V?
( 0< Vin < 1.4V)
Why Vout = 0 for the half cycle?
This is full wave rectifier and therefore, Vout should not be zero there.
For part b, your answer is not correct.
How do you calculate the output voltage?
Could you upload your work with details on how you get that result?
anhnha
Joined Apr 19, 2012
904
Anhnha
Why 1.4V in part C ?? And positive voltage ?
I was referring to the positive half cycle. However, the same goes for negative half cycle.
For 1.4V, I think as Vin is less than the total drop voltage of two diodes, Vout will be zero.
Am I right?
anhnha
Joined Apr 19, 2012
904
Well, sorry for the mistake. I misread the question!
So, manking's answer is not completely correct.
For -0.7V < Vin < 0V, Vout should be zero.
manking:
Could you show the input waveform along with your answer? This will make it easier to see if you are right or not.
anhnha
Joined Apr 19, 2012
904
Please see the equivalent circuit with diodes D3 and D4 replaced by R3 and R4 respectively.
Now for the positive half cycle:
1. Are diodes forward biased or reverse biased?
2. What are voltage drops across these diodes?
3. Can you calculate Vo now?
Now for the negative half cycle:
2. If the diodes are reverse biased, remove them from the circuit.
anhnha
Joined Apr 19, 2012
904
what should i sketch for part c.for 0V in first half period and 9.3V in the other period or exchange the position??
Please look at this.
For the negative half cycle:
With -0.7 <Vi< 0, diode is OFF and Vo = 0.
With Vin< -0.7V, diode is ON and the voltage drop across diode is 0.7V.
Can you calculate Vo?
For the positive cycle, diode is OFF.
What is Vo?
manking4211
Joined Apr 30, 2014
15
1. Are diodes forward biased or reverse biased? F.B
2. What are voltage drops across these diodes? no voltage drop
3. Can you calculate Vo now? peak Vo is 10 like sine wave
1. Are diodes forward biased or reverse biased? R.B
2. What are voltage drops across these diodes? any voltage drop
3. Can you calculate Vo now? 0V
is it look like this??
anhnha
Joined Apr 19, 2012
904
You are correct about the positive half cycle. However, please answer the negative half cycle questions.
manking4211
Joined Apr 30, 2014
15
1. they are reverse biased
2. R =R3+R6+R4=22ohm
3. I DONT KNOW HOW TO DO USING V=IR
