The ground should be put at the bottom not there.
That seems right except the negative cycle.
I think that is because your diodes are not ideal. There is some voltage drop across these diodes.The peak voltage is still not 10v
why?
Sorry, maybe I am wrong. I am simulating it now.Why the ground place at the bottom but not on that position??
Not according to the questions in post number 1.The ground should be put at the bottom not there.
Thanks. It seems that the voltage across R6 remains unchanged if I move the ground point anywhere around the circuit.Not according to the questions in post number 1.
You are measuring the output across R6.
I don't think that is a valid statement.It seems that the voltage across R6 remains unchanged if I move the ground point anywhere around the circuit.
I just simulated all cases and I am right. The voltage across R6 doesn't change at all.I don't think that is a valid statement.
