From battery to solar cells - drone
oookey
Joined May 24, 2010
70
Hey everybody! Is there any way to determine the current consumption of a drone, when its battery (Li-ion battery) rating is 500mAh 3.7V and when the power consumed 70%, it can no longer sustain the flight.
From full charged drop to 30% the power takes about 7~9minutes.
Mine intention is to substitute the battery by using solar cells.
thanks for your time.
Alec_t
Joined Sep 17, 2013
15,167
Take average drone current = I Amps, flight time = 8 mins.
So, I x 8/60 Ah = 0.7 x 0.5 Ah.
Hence I = 0.7 x 0.5 x 60/8 = 2.6 Amps.
oookey
Joined May 24, 2010
70
Thanks for the worked out.
However this current is the total consumption in 8min when coming to a selection of solar cells, how do I pick the suitable wattage of cells in order to supply the drone?
Should I base on 3.7V x 2.6A ~10W cells? Any suggestion?
