can some one explain why we substitue s by jw in frequency response
thank youhi avyan.
This explains
E
The reason why S=jω is chosen to evaluate AC signals is that it allows to convert the Laplace transform into Fourier transform. The reason is that while S is a complex variable, what's used in the Fourier representation is just the rotational (imaginary) component, hence σ=0.
thank youSetting s=jω allows us to evaluate the magnitude of a transfer function along the jω axis as a function of frequency alone. We could also evaluate it along another path in the left half plane which would then have an exponential decay as well as a dependence on frequency. We can of course do the same thing with phase. When you do this you get the familiar Bode plots.
by Jake Hertz
by Steve Arar
by Luke James
by Luke James
