Frequency Response of a trans-impedance amplifier
hoyyoth
Joined Mar 21, 2020
531
I am designing a TAI using this tool from Analog devices. The circuit and it's frequency response obtained from the design tool is given below.
Circuit Diagram:
Frequency Response
I simulated the same circuit in LTspice the only change I made is instead of dual supply I used single supply.I did not considered photodiode capacitance here.I will be biasing the photodiode as as shown in the first image.
In my circuit I am getting a bandwidth of only 10Hz!!!. Please find my simulation results below.The simulation file is also attached here.
May I know where I went wrong.
Papabravo
Joined Feb 24, 2006
22,111
When you switch to single supply operation it is customary to adjust your reference point to 1/2 of Vcc and ensure that the input(s) remain within the range [0, Vcc]
Papabravo
Joined Feb 24, 2006
22,111
I tried that also but no change in the bandwidth
It is not supposed to change the bandwidth. It is supposed to avoid saturating the output or going into non-linear behavior for an input approaching the rails. You must not have been paying attention when that feature was being discussed.
hoyyoth
Joined Mar 21, 2020
531
I just simulated this circuit I obtained from Analog devices.Feedback resistor is 1 Megha Ohm.I know femto I won't get.
But Why I am not getting the bandwidth which AD tool is getting
