Forward-Reverse status LED for H-Bridge
Rahulbk
Joined Jun 21, 2017
5
Hey guys,
I'm planning to use this circuit to build a motor direction controller. I'd like to add 2 LEDs to indicate the Forward-Reverse status. How do I connect the LED without causing damage from reverse voltage? I'm powering the motor with 12V. A schematic would be greatly appreciated. Thanks.
ian field
Joined Oct 27, 2012
6,536
Hey guys,
AFAIK: You can get inverse parallel pair LEDs in a single package. Red with one direction, green the other - feeding it AC produces yellow.
don't forget a current limiting resistor in series.
Rahulbk
Joined Jun 21, 2017
5
If I were to use the LEDs I have lying around, connecting them anti-parallel, with series resistors, would be enough?
bertus
Joined Apr 5, 2008
22,988
The forward voltage of one led will protect the other led.
With no protection, a led can go defective with more that 5 Volts in reverse.
Bertus
