Making a DC motor rotate forward and reverse without Relay
BobTPH
Joined Jun 5, 2013
11,660
Are you talking about a relay external to the valve assembly used to activate the green wire or a relay internal to the valve assembly that is switched by the green wire?
sksanthosh
Joined Jun 15, 2024
internally there is relay that will change direction
its a 2 no 2 nc relay
is there anything like IC that replaces the relay.
BobTPH
Joined Jun 5, 2013
11,660
You are going to have to open it up and remove the connections to the existing relay, while keeping the limit switches. Then you need an H-bridge switched by the green wire.
What is so wrong with the way it works now that you would want to go to that trouble?
