Hi
I am looking for a basic circuit diagram for a forward and reverse control for a sliding gate.
The motor load will be switched through 2 relays. The activation will be controlled by a pulse. The supply voltage is 12 Volts and the motor is an old windscreen wiper motor.
Basically when the button is pressed I want the gate to open or close, when it gets to the end limit it stops and waits for another pulse to run in the opposite direction.
Many thanks
Rod
Many thanks
Rod
