FM Transmitter 60Hz Hum
Chris65536
Joined Nov 11, 2019
270
After reading some recent posts about the problem of a 60Hz (or harmonic) hum on audio signals, I remembered an odd one that I encountered. I have a Ramsey FM25b transmitter that I use to distribute music in my house. I have the output power turned down, so the signal doesn't even reach the street, but that had nothing to do with this problem. It had a persistent 60Hz hum, and turning up the RF power actually made it worse. I tried all sorts of filtering on the power supply, but still there was the hum. I even tried powering it from a 12v gel cell, using my cell phone as the audio source, but it still hummed!
This problem was eventually solved by removing the the PCB mounted whip antenna, and connecting a piece of coax running to an old VHF dipole 8 feet above. So my question is: How could only the antenna's proximity to the transmitter PCB, cause a 60Hz hum?
Chris65536
Joined Nov 11, 2019
270
It seemed like the location of the transmitter and antenna didn't matter too much, while the proximity of the antenna to the transmitter made a huge difference. I could hold the dipole close and the hum would come back. If I turned up the RF power, the hum got louder. Hummmmm? It's a mystery.
vu2nan
Joined Sep 11, 2014
357
I suppose it's an RFI problem - antenna proximity resulting in RF getting into the power supply leading to regulator malfunction.
Regards,
Nandu.
Chris65536
Joined Nov 11, 2019
270
Thank you. Isn't it odd though, that it was modulated at 60Hz? I guess the power line frequency is everywhere inside the house, and it was somehow affecting the RF feedback. It was an odd problem, which was unavoidable using the PCB mounted 1/4 wave antenna.
DickCappels
Joined Aug 21, 2008
10,661
Looking at Audioguru Again's thoughts in post #2 brought about the idea that if the problem is in some way 60 Hz hum entering the transmitter via the antenna, a high-pass filter might help a lot by keeping the hum out.
In the test in which you powered the transmitter with a gell cell and fed audio from your cell phone, was any part of the transmitter including the "ground" connected to anything plugged into the AC line? If so what was that?
vu2nan
Joined Sep 11, 2014
357
Hi Dick,
Here's a video which demonstrates the problem and its solution!
It appears to be a case of induced RF/mains hum mixing at some rectifying junction in the shack wiring and getting reradiated.
Regards,
Nandu.
DickCappels
Joined Aug 21, 2008
10,661
This is to gaurd against the rectifiers in the power supply that powers the transmitter and any audio source becoming part of the transmitter's antenna system, which is what I have found to be the most troublesome source of hum in the transmitters I've made.
Yeah, I know its an old thread but there was some progress since the last time I saw it.
T1 and T2 are common mode chokes. Yes, T2 has four nearly identical windings on it. This particular diagram if from a FM transmitter that I made for a relative. For my own home I managed to get by winding the audio cable and the power cable two-in-hand on a single ferrite bar.
