Hi. my project was to make an fpv setup that sends out an ntsc signal through 5.8ghz bandwidth. i was wondering if i could use a high speed comparator to create a 5.8ghz fm signal. how i intend to do this is by applying a 5.8ghz triangle wave to the non inverting input of the comparator, and then the approx20mhz ntsc signal to the inverting input to change the am ntsc video signal into fm. i thought of this concept when i was looking at how a class d amp works. will it work? is there even a comparator/opamp that even switches as fast as 5.8ghz? can it transmit the signal through an antenna?
ive been looking on the internet for quites some time now and i cant quite seem to be able to wrap my head around the other methods of modulation out there. many suggested using a phase controlled loop, by tricking the vco to oscilate faster then the input signal to increase the frequency to something tht can be transmittted, however this requires a signal divider. for my application a 20mhz signal the divider would have to have a factor of 290. i have no clue in the slightest on how i would achieve that. any help would be great . also if you have a more legitamate way i can construct a circuit for my application that would be great too. Thanks in advance.
ps. my punctuation is terrible because i am used to microsoft words autopunctuation and auto capitalisation and never learnt how to type properly cuz im a moron
