Fluctutations in dc when relay operated
muralikrishna426
Joined Dec 12, 2019
When i am switching relay on and off i am seeing some fluctuations in my DC supply, I am using freewheeling diode also. I am not able to solve this problem. Please advice some solution for this problem.
ci139
Joined Jul 11, 2016
1,989
if the supply provides power to to the switched contacts of the relay ← (then) it's trivial
if the supply does not provide power to to the switched contacts of the relay ← it's the relay coil being connected(/powered) and disconnected(/un-powered)
