Homemade switch: Two layers of plastic 10 mm combined X 200 mm supported by two metal strips 5mm X 2 mm at edges. Two short strips of Cu foil , one on base one on edge of bottom of plastic. It took 14 lb. to make contact. With a solid sheet of plastic, pressure will be greater.
