Flickering LEDs: how to fix?
KJ6EAD
Joined Apr 30, 2011
1,581
It looks like you could just have a cold solder joint that's intermittent. Try reflowing the solder on those three LEDs.
On further review; all of the joints on the board are poor.
28,157
Indeed! quite a few of the connections look questionable, and I have found that solder connections are often the cause of failures on many different kinds of electronics. But you do need to avoid overheating the LED devices when soldering.
