HI Guys , i have need to make a flexable pcb strip that hold IR sensors , the flexable pCB will be encased into fabric band that will need to flex ( 50mm raduis )
I am aware that you can get stiffeners fitted and semi rigid flex pcb to be made as well ,
Was wondering if any who have made flexable pcb , that have smd components mounted on the flex pcb , can advise on the robustness of using/ mounting components to a flex pcb ?
Regards
Sheldon
Regards
Sheldon
