Flat Motors
beatsal
Joined Jan 21, 2018
425
I have a flat motor which is part of a turntable. It has 4 coils that are stationary and a permanent magnet in a toroidal shape that runs above the coils. I want to modify this so as to generate meaningful power say to drive a bike. Any ideas?
Glenn Holland
Joined Dec 26, 2014
703
I had one of those pancake motors just like yours. It is a low torque device that won;t produce much horsepower or generate any more current than it draws when running as a motor.
18,108
A turntable motor is very low power compared to a bicycle. And I’m not sure what you’re thinking of when you say you want to generate power to drive a bike. What would supply the power and why not just use that instead of converting a couple times? Every time you convert from electric power to shaft work or vice versa, you lose power.
beatsal
Joined Jan 21, 2018
425
Thanks to you both for your replies. I want to supply it with 24VDC from a battery. The magnet is quite powerful. I am thinking of scaling it up by adding bigger coils but first would like to find a motor controller chip that I connect to 24 VDC and the chip would connect to the motor. The present system uses transistors (about 8 in all), this is cumbersome. Any ideas for a motor controller chip? I can send you the circuit diagram if needed.
Alec_t
Joined Sep 17, 2013
15,121
I doubt you'll find a single-chip power-handling solution (though I'd like to be proved wrong). The transistors are presumably power types and generate heat, which has to be dissipated; hence space is needed for heatsinks or other cooling arrangements. I wouldn't expect any alternative system to be less cumbersome.
-live wire-
Joined Dec 22, 2017
959
You will want to buy a motor like this. And you will not find power transistors and a μC integrated into one chip. It is completely impossible for the required power. And you will also need an expensive lithium battery. Lead acid would be far to heavy. A YouTuber, great scott, made an ebike. You can check it out to see what's involved.
beatsal
Joined Jan 21, 2018
425
Thanks.
If a single chip is not available, any ideas how to do it with a min. number of discretes?
beatsal
Joined Jan 21, 2018
425
All it is to deliver 4 pulses 90 deg apart and then feed these pulses to power transistors. I do not have the expertise to do this so any ideas welcome.
