A turntable motor is very low power compared to a bicycle. And I’m not sure what you’re thinking of when you say you want to generate power to drive a bike. What would supply the power and why not just use that instead of converting a couple times? Every time you convert from electric power to shaft work or vice versa, you lose power.I have a flat motor which is part of a turntable. It has 4 coils that are stationary and a permanent magnet in a toroidal shape that runs above the coils. I want to modify this so as to generate meaningful power say to drive a bike. Any ideas?
I doubt you'll find a single-chip power-handling solution (though I'd like to be proved wrong). The transistors are presumably power types and generate heat, which has to be dissipated; hence space is needed for heatsinks or other cooling arrangements. I wouldn't expect any alternative system to be less cumbersome.The present system uses transistors (about 8 in all), this is cumbersome.
Thanks.You will want to buy a motor like this. And you will not find power transistors and a μC integrated into one chip. It is completely impossible for the required power. And you will also need an expensive lithium battery. Lead acid would be far to heavy. A YouTuber, great scott, made an ebike. You can check it out to see what's involved.
