Flashing LED affecting power
eromlignod
Joined Dec 8, 2012
8
Hi guys:
I'm experimenting with a circuit where I'm flashing an LED at 1kHz. Elsewhere in the circuit I have an unrelated analog (AF) signal from a sensor. It is a very small signal that is later amplified.
My problem is that the 1kHz signal is appearing in the power and ends up in my analog signal. I can see it in the +5 leg with a scope. The LED pulls about 80 mA with each pulse (40 mA RMS). I have bypass-capacitored it with no luck. I also can't seem to filter it from the analog with a HPF. It's small, but so is the signal and both end up in the amplifier output. It just seems to be omnipresent.
What other reasonable options do I have?
Don
LowQCab
Joined Nov 6, 2012
5,101
Supply us with a complete Schematic so that we'll have something o analyse,
along with an explanation of what the LED is supposed to do.
