A possibility is one of the numerous electronic roulette wheel kits, but I don't know how many of them have realistic decay.I was hoping to make a beep sounds like the Price is Right giant spin wheel. Beeps fast during the spin and slows down as it loses momentum. Are there any pre-existing designs for something like this? Thanks.
What is the "wheel" that you are using?I was hoping to make a beep sounds like the Price is Right giant spin wheel. Beeps fast during the spin and slows down as it loses momentum. Are there any pre-existing designs for something like this? Thanks.
You can get piezo sounders with built in electronics - the Sonalert is one of the best known and probably as loud as you need.What could you use to amplify the buzzer sound? This will be at a fair so there will probably be loud background noise.
Will I need to get a relay and larger speakers?
Sorry for the noob questions.
As @ian field said just get a better buzzer. Make sure it is a Continuous tone buzzer & that the reed switch can handle the current.What could you use to amplify the buzzer sound? This will be at a fair so there will probably be loud background noise.
Yes.If the reed switch lands near the magnet on the pinwheel, won't the beeper continue to have one long continuous beep?
Yes. But it isn't as simple as a battery-switch-beeper circuit.Is there a way to limit the beep even if it closes/activates the reed switch?
Yes.
What you are describing is having a constant beep time that is short enough for when the wheel is spinning, but shuts off after a fixed time interval even if the wheel stops with one of the magnets sitting on top of a switch. The circuit is called a monostable, short for monostable multivibrator. A 555 circuit (LMC555 is better for battery operation) can do this, and probably drive the beeper directly. You should get plenty of volume with a 12 V battery or power source. How comfortable are you with assembling a small circuit, either on perf board or using a solderless prototyping board?
There are many ways to do this kind of timing circuit. With this simple circuit, the beeper might sound continuously at high wheel speeds, with individual beeps becoming distinguishable at medium and slow speeds. This is a consequence of the timing capacitor no having enough time between triggers to fully discharge. A counter-based circuit does not have this problem, but is a bit more complex. I think a 555 circuit will work here.
Have you selected a beeper to use? Where are you located?
| E | The right stuff - "beep beep" circuit | General Electronics Chat | 19 | |
Help figure this beeper circuit out | General Electronics Chat | 21 |
