MaxHeadRoom
- Joined Jul 18, 2013
- 30,654
Either that or it is a RPM top speed limiter.
So what were the results of the voltage test?
Max.
Max.
No legend on them?I will do so once reverse engineered as i'm not 100% sure they're transistors...
The gate threshold voltage is where the MOSFET just starts to turn on (see the red boxed entry on the data sheet exerpts attached. The other plots show how the drain current varies with VGS and VDS.At first glance, the MOSFET appears to be a logic level one, the gate threshold is typically 3v.
http://www.st.com/content/ccc/resou...df/jcr:content/translations/en.DM00123510.pdf
| Thread starter | Similar threads | Forum | Replies | Date |
Help fixing volvo cr 905 fm module | Technical Repair | 0 | |
Fixing SainSmart 16-ch relay module | Technical Repair | 0 | |
Fixing the SR latch | Digital Design | 24 | |
| Y | biasing misgelighnment fixing question | PCB Layout , EDA & Simulations | 1 | |
| N | Plasma TV no display just powering on | General Electronics Chat | 6 |
