Thank you Dana for your through solutions.
I have to tell you that I have only basic knowledge of electronics and I looked at the problem which I mentioned at the beginning of this thread as a designer of what I have in mind. I would have to spend more time to continue with the solutions you offered because I would have to read more about them. But theoretically, I have implemented the solution using counters, dividers, full adder and subtractor which are clocked by crystal time base generator and I did not consider any possible issues such as latency. With my initial question I needed to know if it would be possible to implement the adding and subtracting of the frequencies directly on the frequencies themselves to simplify the circuit. Unfortunately I cannot follow up with micro-controller kind of solution now so I have to be satisfied with what I did.
But maybe you could tell me if my counter, divider .... solution could produce precise results or not with frequencies between lets say 1 and 200.
