422 pulse width
MikeJacobs
Joined Dec 7, 2019
232
Im trying to look at some 422 differential pulses on a scope.
running t 115200 buad rate.
I am doing the math in the scope so i can see the diff signal of A-B essentially.
I am trying to understand what the pulse width of each logic one or zero should be so i can decipher what is being output on the scope.
How can i calculate the pulse width of a logic bit?
obviously 1/115200 is ~8uS per bit but I'm not sure that really means the pulse width of that bit is truly 8uS.
Any thoughts on how to assume the pulse width?
Ian0
Joined Aug 7, 2020
13,281
Ok, i must have another problem them because im seeing 500nS pulse width running at 115200 baud
Yes. There should be no 500ns pulses on a 115200 baud datastream. If it is RS422 then there is a slight possibility of an odd pulses when the driver is enabled and disabled.
MikeJacobs
Joined Dec 7, 2019
232
Can you explain a bit more. I am seeing a a start bit that is about 25% of the pulse width of the other bits and them what appears to be a random logic zero bit before the 8 bit LSB starts in little endian order.
Any ideas?
Ian0
Joined Aug 7, 2020
13,281
each byte is framed by a start bit (space) and a stop bit (mark). Is that what you are seeing?
Space=0
Mark=1
but on RS232 everything is inverted.
on RS422 you get both inverted and non-inverted signals.
